I've just bought 2 pairs of Alpair 10P's to make 2 sets of speakers - decided to go for a mid sized 2 way floor stander design.
The plan is to use the Alpairs in an open baffle down to 300-350hz or so, and side mount two 6.5" woofers per cab, kind of like the Kef Blade (also 350hz x/o)- altho the woofers will be close to the floor, more similar perhaps to something like Rockport.
I want to use a 1st order on the Alpair and 2nd on the side firing woofers, which will probably be Scanspeak 8535-01 in parallel. The cabinet baffle will lean back around 9 degrees for time alignment
what do you think…? will there be an issue using the alpairs in an open baffle down to 300hz with just a first order roll off? will there be issues with driver integration? I'm willing to take the risk etc
