So first let me say thank you to DIYsoundgroup.com and Curt Campbell. you guys rock! also special props to Erich. he graded his packing job on my packaging an A+...he wasn't lying. he really did put an A+ in my packaging. and to the person who invented this tapped horn- outstanding work!
so this build is for my 10 year old son. i will be using a dayton dta150 amp in bridged mono for the sub and a hand me down nakamichi ht receiver for the fusions.
first things to say:
the anarchy kit is not for a newbie that has no confidence with wood working. everything fits great- minus one board that was just 6" longer for no reason. easy fix. made sure everything else was correct then chopped it to proper length. you have to juggle quite a few things all at once when assembling. took me 1 hour 45 to get it all assembled. buy a few corner clamps...makes everything so much easier.
edit: skip the door! erich said it's ok
i recommend adding a way to get the woofer out should it blow. what i did is make a board to place over the stock board before gluing up the back. screw them together in between where you want the door. then i raised the blade to 1/2" and cut just the stock material. presto! a door to the woofer.then glue up the rest of the back.
mock up is key! this is where the clamps come in. make sure everything is correct THEN start attaching things to each other. if you don't, you will never get any kind of fasteners in between the boards. install everything in modules. check the fit, then add more. you'll see what i mean.
tomorrow me mike220 and jcsquats are building the fusions and a digger 8 sub. i will update with pictures tomorrow. have a beer filled night!
edit: playing all the speaker for a few hours now... getting better by the minute. have to high pass at like 20 to protect the sub, but i have a work around for music. sick! movies still need to be thought about. really low makes the bad sounds come out, but that is lack of protection on my part. the digger is gonna be impressive when it is out of my garage.
