I figured I'd start a thread for this build rather then post it in my " Two Way High Efficient" thread. I'm going to use the Audax for this build rather then try to push it to low in a 8" two way. I should be able to cross it to the TB75 1558 around 2 kHz. Ive not worked with the Deltalite II 2512 so I'm not quite sure were I will cross it to the TB75.
I got the double waveguide worked out pretty well. I mounted it to a piece of 3/4" MDF using silicone to attach it. Stiffened it right up. I'm going to set it into the baffle and attach it from behind.
Mounting plate for the drivers plus stiffening plate.
This is the back of the baffle with the guide set into it. I am going to facet the baffle edges so I will need to put two layers on the back. This is with one.
And the second layer
I made up a sled to cut the angles
Flip the sled around to cut the other side
Finished off with a hand saw
