Re: Deltalite II 2512- TB75 1558-AudaxTW25A8 Combo Waveguide
I noticed a lot of things that were improved upon as soon as I started listening. The two you mention are among them. Better instrument separation, more 3D imaging and much more realistic sound. Unfortunately I'm not sure why. Is it the 12" woofer, the double waveguide, the dome mid, the Audax tweeter, the light weight cabinets or the controlled directivity. Probably a mix of all of them. They are also very dynamic. Probably from the high efficiency along with the 12" woofer.
During my listening to individual drivers I found I was crossing the TB 75 to low with the 11x6 guide. When I would turn up the volume I would hear, hard to explain, but kind of like a megaphone effect. It was an uncomfortable sound. Just raising the the crossover 100 dbs, going stepper on the crossover slope and filling back in with the Deltalite removed it.
The issue I was having between the Deltalite and the TB75 seems to be a phase issue. I don't quite under stand what was going on but I was getting cancelation above the crossover point. Lowering the slopes on the Deltalite did not get ride of it and raising it would boost above this point before it would the cancellation. The odd thing was PCD was not showing this. It was showing a 3 db boost in that area. When I flipped the polarity the cancellation disappeared. When I flip the polarity in PCD I get a reverse null. I'm now running with all three drivers the same polarity. I originally had the tweeter and mid flipped. I still need to laminate the cabinet so when I open it up I'll check to make sure I didn't switch the polarity on the drivers. Even if I had it should still have matched the FR in PCD just opposite.
Originally I had the tweeter/ mid crossover at 2.2 kHz and had it as low as 1.8 and the Audax sounded good at hi volume at either spot. It just ended up at 2 kHz.
I have the speakers toed in just in front of my listening position and I can lean left or right as far as I can, without falling out of my chair, and the image stays stable. Not quite as pin point but pretty descent. The thing I like the most from these speakers is the dynamics. the 12" Deltalite seams much smoother then the 8" B&C that I've worked with. Hard to explain other then it just seems to be a little softer sounding which I like since I'm use to hi fi woofers. The Deltalite plays pretty low but adding a sub makes a big difference. I've been running my Dayton RSS265HF in a 1 sq. ft. Box with a 250 watt dayton plate amp and it seems to be keeping up just fine.
I have a total 10 parts in the crossover. Two on the woofer, four on the tweeter and four on the mid. I'm running just a one ohm resister before the crossover on the mid and just a 3 ohm resister parallel across the tweeter. I've not tested how loud they will go yet but so far I haven't needed to.
Dave
Originally posted by TN Allen
View Post
Dave
