Amp for my Sundown Audio SA-12 Dual 2 ohm sub
  • Amp for my Sundown Audio SA-12 Dual 2 ohm sub
    Because I have no car, my car audio gear has now become my home audio gear. I've got a Sundown Audio SA-12 dual 2 ohm subwoofer. I'm looking for a amp to drive them, but i'm nervous about the reliability of various amps on PE. Form off board amps to plate maps, i don't want to buy from PE, get it shipped over to the UK (at a tremendous shipping cost!!) only to have it fail, then go through the expense of sending the thing back.
    Away from that, any advice on what's out there. I was looking at some Emotiva amps, but any suggestions would be helpful.
    Budget - I'm looking to invest in an amps at the latter part of the year, but i was looking around $300-400 tops.
    Power - Around 300 - 500 watts, don't care if its class D.
    I would prefer a single channel amp, but if there's a 2 channel that's bridgeable ....
    I was looking at this
    Or should I just get a Peavy amp or some form of PA amp/power amp and a volume controller?
    Re: Amp for my Sundown Audio SA-12 Dual 2 ohm sub
    Do you have 1 or 2 subwoofers to drive? First you say a subwoofer, then you say them!
    “I cried because I had no shoes until I met a man who had no feet”
      Sorry, I have one subwoofer.
        Wired in series for a four ohm load any plate amp would work. You might want to look for one in your country for easiest service.
        You could also use a crown amp. But often you will need a rca to balanced converter ($50) to get the levels up.
          I second what Duanebro said.
          I have this amp: http://www.parts-express.com/crown-x...ifier--245-502
          and needed to use this to get the line-level outputs to an acceptable level: http://www.parts-express.com/art-cle...erter--245-868
          It's a little more than you wanted to spend, though.
          That amp was recommended to me my several folks here, and it's pretty powerful and works good as a sub amp with it's built in crossover. Plus, you won't have any ground hum issues with it I don't think.
          Also, consider that it's flexible for future changes in gear... for instance, you could run your existing dual voice coil 2 ohm sub directly from the R and L outputs now, or later on, wire them in series to make a four ohm load connected to one channel of the amp, and hook up another sub on the other channel in the future. Lots of options with that amp.
          TomZ
            do you plan on adding any more subs to the system?
              I use a Bash 500w plate amp. Plently loud for the SA12 I have it paired with.
