Hi All,
After 2 months straight of tinkering, fixing and troubleshooting, I finally have something to show for. This is a class AB kit using a pair of MOSFETs, with a claimed output of 150W into 8R and 300W into 4R. This build in still in progress, but music is playing, so I decide to post this project.
1. Enclosure: the case is made out of 1/2" MDF laminated with black glossy formica. The top will be clear 1/4" acrylic with perforations for heat venting (still working on it). I lined the bottom of the case with a Home Depot aluminum sheet to provide a grounding plate for the equipment. Earth ground is connected to this sheet from the ground plug of the IEC receptacle. The front and rear panels are held by metal angles and screws, so can be removed if needed. The power button (Apex Jr.) is the same that Ron used in his project. And before Mr. Cottiers can photoshop my front panel, I will have a pair of VU meters installed soon. The rear panel houses the regular RCA and speaker terminals, the fan, fuse and the IEC receptable.
