Scan-Speek 4" for 49 cents?
NS6-ed
I have completed testing on 2 sliced Aurasound NS6-255-8a samples and decided to bury the data here. These are unworthy of their own thread. Whoever it was that convinced me to buy these must be deaf.
3 NS6s baselined showing 3rd order distortion-
The slit technique definitely works for suppressing the break-up.
The slits destroyed the peak completely, and reduced the related 3rd and 5th order distortions by the same 8-10 db.
Sample-5
What it did not do is make the driver into something I would want to use. I can't stand to listen to them raw or modified.
There is one big problem that I may or may not address in this round of drivers. Distortion below 1k rises when testing the NS6 at high volumes. This indicates that the glue is too soft(which I suspect), the gap is too wide, or the floppy-coned NS6 is just not suited to this mod.
MY advice so far- sell the NS6s, keep the NSBs, and cut everything but don't glue yet!
Originally posted by Tin_Ears View PostYeah, but could he put up with all the noise without going insane?"Looks like you may have to design your own speakers. Its not that hard." -DE Focht
Diffraction Happens
Re: Disregard
Originally posted by Tin_Ears View PostThis thread is getting really exciting. I hope you can stick it out until all those slits are fully explored.SEC DIY 2014 Speaker Show is on! *November 8th*
Wanna win a set of Newform Research R30 ribbons?!?!
SEC DIY 2014 Thread
SEC DIY 2012 Speaker Show
SEC DIY 2011 Speaker Show
Re: NS6-ed
Originally posted by Sidi View PostI guess I don't understand... ...They sound quite pleasant in a system.Originally posted by Sidi View PostAre you modifying them to use as a full range driver only? They aren't a full range."Looks like you may have to design your own speakers. Its not that hard." -DE Focht
Diffraction Happens
Re: Disregard
Originally posted by johnnyrichards View PostThis thread has become 8th grade level. Nice job, guys."Looks like you may have to design your own speakers. Its not that hard." -DE Focht
Diffraction Happens
Re: NS6-ed
Originally posted by jbruner View PostIt's a driver evaluation. My opinion is that the driver sucks. I showed measurements that partially reveal why. It's obvious that someone would try to deal with it's flaws when designing a system. But the driver offers no low bass, poorly defined mid-bass and garbled mids. It's a lousy woofer that has to be crossed at 1500hz to avoid that 3rd order distortion. Doesn't sound very useable to me. Very Astute, Great Intelligence Never Assumes.
Re: NS6-ed
Originally posted by jbruner View PostI have completed testing on 2 sliced Aurasound NS6-255-8a samples and decided to bury the data here. These are unworthy of their own thread. Whoever it was that convinced me to buy these must be deaf.
Sample-5
Apparently not."I just use off the shelf textbook filters designed for a resistor of 8 ohms with
Re: Scan-Speek 4" for 49 cents?
Originally posted by jbruner View Post...Here is the response of sample 1 before and after Revelator style cut and glue job.
Blue is modded, brown is baseline. I added a small piece of duct seal to the slit dust cap to smooth the top octave on this one.
The net result is very impressive. The primary break-up is reduced by 11dB, distortions of all orders are lowered, and subjective sound quality is much improved.
In other words, there is no downside, unless you like the sound of paper cone break-up.
What voltage did you charge the (dust) cap to?
Originally posted by jbruner View PostI probably need to stop at this point and clarify my intentions....
I wanted to find out if the well-known slit-cone method had any drawbacks. Could you damp the out-of band resonances without hurting the Clarity, Liveliness, Immediacy, Transparency?
Regards,
Rob
I hope this isn't derailing...
What if the NSBs are crossed at 3K/24dB? Will the "unmodified" cone breakup still be an "audible" issue? What about 3K/12dB?"We are just statistics, born to consume resources."
~Horace~, 65-8 BC
