OS Boombox build
  • #61
    Re: OS Boombox build
    Originally posted by joeybutts View Post
    Could you have recessed them at all to tighten it up a bit?
    it does help but still loose ...
    Paper Towers
    RS180P/28F surrounds
    Boombox
    • #62
      recessing both worked great and they went together ...
      unfortunately i can't get them apart ....
      Paper Towers
      Boombox
      • #63
        probably need the recess to go high enough to allow for the movement.....
        • #64
          yeah this was a quick test . i got them apart but it took a hammer ...
          Paper Towers
          Boombox
          • #65
            Recess a slot above the tab.....money.
            • #66
              i just did them equal and a lil shallower , worked but lose . the marine industry uses these that are spring loaded , gonna try and get over to the coast this weekend and see if i can pick some of those up ...
              Paper Towers
              Boombox
              • #67
                All you need to do is recess that slot up above the one that you aren't moving and it will be great. I know what I'm doing for mine now. Thanks for doing all the trial and error for me. :p
                What those cost you, $3?
                • #68
                  no problem , its good to finally give something back to this community ... pack of two was $3.50 at Lowes ...
                  Paper Towers
                  Boombox
                  • #69
                    you were correct , still a little tough to separate but while i had everything set up ...
                    Paper Towers
                    Boombox
                    • #70
                      thanks for the help Joey , this is what i ended up with , its working great ...
                      only thing left to mount is the rubber ducky antenna . gonna start breaking it down and applying bondo ....
                      Paper Towers
                      Boombox
                      • #71
                        progress ... drilled and set hurricane nuts and got everything broke down and first coat of primer on the OS's . my antenna did not come in today so i'm forced to hold off on the sub box ...
                        Paper Towers
                        Boombox
                        • #72
                          What are you going for?
                          • #73
                            dupla color rattle can . GM dark blue metallic ...
                            Paper Towers
                            Boombox
                            • #74
                              Paper Towers
                              Boombox
                              • #75
                                keep rollin rollin rollin.....
