2x250 IRS2092 amp build
  • #61
    Re: 2x250 IRS2092 amp build
    When this thread is brought to a conclusion I will calmly check into a rehab facility....:D
    Insane in the membrane...
    NLA
    • #62
      Originally posted by [email protected] View Post
      When I finish my Polk redo, I will re-wire to have 8 parallel caps per rail and loose the ground.
      Like this one.
      Except I'll wire the rectifiers right unlike this one.
      You might want to remove or fix that picture. Someone could find that picture and wire it just like the diagram show without realizing the bottom half is wired wrong. They will blow their caps for sure.
      • #63
        OK... A picture is worth a thousand words, so here are the schematics of a basic PSU using one or 2 bridge rectifiers. Optional components such as bleeders, snubbers omitted for clarity purposes. Can we agree on this? Thanks.
        Hong
        LM4780 Parallel Chipamp
        Sonata Soundbar Project
        • #64
          Hong
          Looks fine. However, I'd draw the ground on the mains connector as a chassis ground or earth ground to remind yourself that this this chassis connection should be made separately, either at the input or through a ground loop isolation network. See the figure below, from this RaneNote), or see the discussion for ESP Project04. It's worth reading that RaneNote carefully...
          • #65
            Got it. Thanks Neil for your guidance.
            • #66
              Almost there Bob.
              • #67
                I agree!
                Sure am glad that we have real experts here who can advise us.
                In addition, I'm now convinced of the pitfalls.. I will never build a power supply with 2 bridge rectifiers.....
                Tangband W6-sub
                • #68
                  Lowell,
                  I'm curious if you can hear any difference between this amp and the other one you built using the two 16,000 uF computer grade electrolytic caps? They both use the same amp module. This one's cap bank should have lower ESR. I'm wondering if that is audible or not. Thanks.
                  Craig
                  I drive way too fast to worry about cholesterol.
                  • #69
                    Hong: So...Did you have a power supply that was wired incorrectly or was there just some confusion with schematics....Same question for Lowell.
                    Bob...... Slowly recovering
                    NLA
                    • #70
                      Hi Bob,
                      All my PSUs built using one transformer and a single bridge rectifier are wired correctly, as indicated in the top diagram of the attachment in post #63. The confusion comes from the Sure board instructions calling for 2 separate PSUs, so I wired two of them together, as shown in this attachment. The rail voltages come out correctly, and in my case, they were -56V/0/+56V. The amp board plays loud and clean, and there is no hum of any sort. There may be a floating ground some where in there, but it did not affect the amp at all. Lowell went down the same road I did (sorry man)...
                      • #71
                        Originally posted by PWR RYD View Post
                        Lowell,
                        Its really hard to say at this point Craig. In my small room, they seem the same. The motivation for this build was to have more power behind it. The first ran out of juice in my home theater during high transient movie scenes. It has 16000 per rail after a 650va toroid. This was meant to have 37000 after a 1000va toroid. The truth is, I don't really know how much capacitance I have. It will be simple to wire all the caps individually in parallel but not sure about grounding it. The schematic Hong posted shows a ground with between caps just like mine. Was said that it was right but mine is wrong. So confusing.
                        • #72
                          By the way, I measured 48vac on both secondaries and 65.3 vdc on v- and v+ with no load.
                          • #73
                            OMG I am hankerin' to build an amp like this. Lowell, the work is amazing and we are licky to have the big guns to prevent our ill fate. I would love to build a 500WPC amp. Are there any out there?
                            • #74
                              Neil can easily tell you how to get the capacitance you want .. diagram wise. You may want to look in to tracing your current wiring so everyone is clear on what's happening and what should happen.
                              I am trolling you.
                              • #75
