I have the Tritrix TL's and want to build a ported CC. I plan to build it with front firing port/s that can be hid behind the grille. I will do a slightly modified enclosure 24Wx6.5Hx12-14D. I will adjust the depth for proper box spec. should I do 2 ports (1 on each end of box) or just 1 port on 1 side? Does/will it make an acoustic difference? How do I calculate for 2 ports if I go that route? Either way I will use slot ports as opposed to tubes. I also am going to build the MT's ported as surrounds
This is my first HT project, however I used to work in a car stereo shop. I just can't remember the rules for porting. (it's was about 15-20 years ago, while in college) All the boxes I've made in the past were for subs in trunks of cars, not HT and placement was not much of an issue.
Thanks in advance for your help and advice. ;)
