RS-P WWMTM 3 Way underway ( pic heavy )
  • Re: RS-P WWMTM 3 Way underway ( pic heavy )
    slow season has hit with a vengeance and the guys at work that watched most of the build wanted to hear them , so ....
    in this big space they look kinda small and sound a lil thin ...
    Paper Towers
    RS180P/28F surrounds
    Boombox
      They look great!
      They are too far from the wall. The bass will improve a lot if they are 3 feet or less from the back wall to the speaker face.
      If anyone is interested, I have begun construction of an all-aluminum version of these.
      "Looks like you may have to design your own speakers. Its not that hard." -DE Focht
      Diffraction Happens
        Originally posted by jbruner View Post
        They look great!
        good call !
        and git - r - done !!! your only a few hours north , maybe i drag these up there for day when i finish them ....
        Paper Towers
        Boombox
          Similar aluminum version with larger mids.....
            i looked at those before deciding to build these Joey , the impedance load scared me . i would of needed a new amp as well . these are 7.5 nominal ...
            Paper Towers
            Boombox
              Yeah, CJD stays pretty dedicated to separates. His stuff is so good though. Love it.
              Definitely would be nice to have an AVR friendly version.
                alright guys i'm gonna need some help getting good measurements . Josh has got the aluminum version together and had to make some XO changes , we're not sure that i'm gonna have to yet but some good pics would go along way . first my mic shuts down on the top octave around 15k in the near field and farther out it shuts down around 7-8k . also my space is very small and cluttered so i do get some noise . thinking of going outside but i do have a busy noisy road out front . i am using UMM-6 and Holm impulse . any thoughts , suggestions or advice would be greatly appreciated ...
                Thanks
                Mark
                Paper Towers
                Boombox
                  Thanks
                  Mark
                  I've had the same issue with HolmImpulse. I had to play with the settings a lot to get it to extend out to about 18.5-19khz. I used a weird sampling rate. Like 170something hz or something and had to keep reinitializing and restarting the stream. I would take a measurement, reset/reinitialize, and keep doing this until I got a response that worked. It only worked on this sample rate. Anythinge else was a little messed up.
                  -Kerry
                    thanks Kerry , here is pic that shows what i'm talking about , i was set up at over 3ft for a whole speaker measurement and took a look at my mid X ...
                    Paper Towers
                    Boombox
                      What is the sweep highpass set at? Anything over about two or three hundred will make the top end drop like a cliff. There's probably no reason to set it higher than 60 hz.
                      One of my computers rolled off the top like that with the headphone connection, but not the other output. (Or it might have been the other way around.)
                      Soundcard issues can be difficult to figure out sometimes.
                      Make sure no one changed the treble setting.
                        highpass was set at 200 . here is what i set up for . both passes checked off from 40"
                        Paper Towers
                        Boombox
                          Is that your loopback measurement?
                            yes
                            Paper Towers
                            Boombox
                              Looks like the soundcard is the problem. What kind is it? Did you turn off all the special effects?
                                that is awful.
