RS-P WWMTM 3 Way underway ( pic heavy )
  • #46
    Re: RS-P WWMTM 3 Way underway ( pic heavy )
    Originally posted by jcandy View Post
    While the approach to designing a speaker with flat anechoic response is fairly standard, the approach to designing one that includes the woofer-floor interaction is less standard. Perhaps Jeff B. could explain what his preferred method is.
    I still take the gated response on the tweeter axis, which in a room is a bit messy. I also do some modeling. If someone follows my link below and has Excel they can download and use my Diffraction and Boundary Simulator. For the boundary portion I would use the power response and very little, if any, room pressurization. Then look at the combined response with the baffle diffraction simulation included for a reasonable approximation of the low end power response. For a one meter on axis simulation switch the boundary graph to "axial" and then look at the combined graph. It's not perfect, but it helps.
    • #47
      all measurements from 2 foot ,same amplitude on tweet axis ...
      top 125
      bottom 125
      tweet
      Paper Towers
      RS180P/28F surrounds
      Boombox
      • #48
        Hey, everything looks a lot better when it's flush-mounted!
        I think something is causing some top octave loss in the measurements.
        Maybe someone who has measured one can confirm, but I believe the Reference silk tweeter has a rising response.
        "Looks like you may have to design your own speakers. Its not that hard." -DE Focht
        Diffraction Happens
        • #49
          Filmslayer.... I know that everyone has there own way of doing things, but what I would do is first make sure that your speaker measurement setup is adequate, and then I'd use gated measurements. Then, I'd take a few measurements of the mids together using a speculated highpass filter. In other words something like 80 uf and 3 mH, and just see what the response looks like. Make a few adjustments, and then add a lowpass to the filter. Something like .6 mH, and 8 uf. If nothing else, you will get some practice, and probably learn a few things as well.
          • #50
            think i my may have blown up a tweet . i was searching for that top octave this morning and turned the amp up just a bit and ran a sweep , i heard nothing wrong during the sweep but i get no sound out of it now ... gonna finish my coffee before i pull it out and switch it . <sigh>
            Paper Towers
            Boombox
            • #51
              switched tweets , other one is ok . putting the suspected bad one back in now ...
              **EDIT**
              yep , its toast ...
              Paper Towers
              Boombox
              • #52
                You can just buy new v.c. assemblies for those, I think at about 1/2 the price?
                • #53
                  Maybe a NPE cap to put in line to save the tweeter, I think it is 100uf for 4 ohms and 50uf for 8 ohms.
                  If we all reacted the same way, we'd be predictable, and there's always more than one way to view a situation.
                  What's true for the group is also true for the individual. It's simple: Overspecialize, and you breed in weakness.
                  It's slow death.
                  //Burn n' Die//Dream Weaver//Maximus//ABC Bookshelf Speakers//Dayton Twin Towers
                  • #54
                    the pro's and con's of testing un-protected were discussed i made the decision , no big deal , chalk it up to a lesson learned . i'll get a new diaphragm when i order XO parts ...
                    tried to get more measuring done . took a look between the lower mid and upper woofer , i need to make some changes in Holm to get a better picture . would really like to get some XO parts ordered this week ...
                    Paper Towers
                    Boombox
                    • #55
                      i'm still trying to get good measurements and just found what may be a problem . my sound card has a microphone boost that was turned up to +24db . will go back and re-measure tonight and see how much of a difference it makes ...
                      i really can't wait to hear this .
                      Paper Towers
                      Boombox
                      • #56
                        Did you by chance miss the HOLM starter guide? Perhaps you can post a picture of your speaker while set up for making measurements.
                        • #57
                          not missed (http://techtalk.parts-express.com/sh...-starter-guide) , and thank you !!! its what got me to this point along with their instruction pdf ... i'd rather not post pics of my place , y'all would die of laughter , true story .... Jbruner is privy to my set up and working with me every night as he is the one designing my XO ...
                          Paper Towers
                          Boombox
                          • #58
                            Great looking build!
                            I've contemplated a similar design for years, but side-firing the woofers to get a little thinner baffle for improved WAF. If that ever happens (LOL) the RS125P/28F combo would be right at the top of my list. I await your conclusions!
                            • #59
                              thankfully i have no WAF .... i have a dog and until she dusts once in a while she has no say !!! :p
                              Paper Towers
                              Boombox
                              • #60
                                OK , i got all the measurements i was asked for zipped up and sent to Josh .
                                my original thought with these being towers was to use out riggers and spikes for a couple of reason . first the tipping factor and second to get the tweeter up a couple more inches . but after putting one together both those are no longer concerns , it is big and stable and the tweet is rite at ear level as it is . i guess my question is , is there any other audible advantages to spikes that i need to consider ?
                                Paper Towers
                                Boombox
