Re: The DIY 2.1 amplifier. Should I build it? Would you buy it?
I've seen a virtual ground driver circuit drawn both ways (with the feedback before and after the series resistor). I think the reason for having the feedback after the series resistor is that the op-amp will compensate for any voltage droop caused by current draw through the series resistor. Which do you think is better? I will yield to your expertise.
Ok - now I understand you. I thought I had designed the circuit to avoid any interactions between the pot and the filter. On the master volume pot (R1), U1A and U1B form stereo buffers to prevent any filter interaction (U2/U3). On the subwoofer volume pot (R2), U4B is a buffer designed to prevent any filter interaction. In case anyone is wondering, the series resistors (R13/R14) are there prevent crosstalk between the left and right channels when the pot is at maximum volume.
I chose to keep the solution as a dual pot because that increases purchasing power and helps reduce the cost. For example, the person who builds the design can easily source two of the same pot form eBay, etc. to help save money. A single pot + a dual pot usually doesn't save any money as versus two dual pots. A lesser reason is that it prevented me from having to create two separate symbols in the DesignSpark software....
I do have to ask, though - why "no ground plane"??? I've been doing audio layouts in PC's and consumer electronics for 15 years, and I'll admit that careful attention must be paid to the grounding, but I certainly wouldn't call out a blanket "no ground plane" rule. My experience has shown that planes are preferred to shield grounding. Star grounding can be beneficial, but it can be complicated to get right. Basically, a star ground can yield better performance than a plane, but it's so much easier to screw up and yields worse performance when it's bad. Do you have some specific concerns here? The design could be done as a one layer board, especially if I were to use jumpers. The pricing for a two layer is cheap enough to not worry about trying to make it a one layer.
Originally posted by fdieck
View Post
View Post
View Post
