Esoteric es25nd-4
Re: Esoteric es25nd-4
Looks like a super low Q alignment. I predicted a sloping response when the original ad-copy read something like "ultra low Qts of 0.2 means wonderful transients" or something like that. Probably benefit from tinkering with the chamber. The Fs may be 475Hz, but it is already down 15 or 20 db from the odd peak right at 5K. Doesn't look too easy to use. On paper, doesn't really stack up to the midwoofer offerings. Of course the valley on-axis centered around 10K will minimize ssssibilance. Just my $0.02 based on interpreting the spec sheet.Don't listen to me - I have not sold any $150,000 speakers.
Okay, someone get this in Dave Pellegrine's waveguides, and then we can see how usable this tweeter is at the bottom of its range:blues: Flat frequency response, a smooth sound power response free of resonance, careful driver-integration, and high dynamic range both upward and downward :blues:
I wonder how much of the damage the faceplate is causing to it's FR?
Originally posted by GranteedEV View PostOkay, someone get this in Dave Pellegrine's waveguides, and then we can see how usable this tweeter is at the bottom of its range"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.diy-ny.com/
screams without the faceplate maybe?Feel free to rip my assumptions apart when wrong, or fix if close.
Passive Radiators:
All PR(s) Vd must at-least double all woofer(s) Vd. Calc = Sd x Xmax to get Vd for all PR(s) and all woofer(s). If all PR(s) Vd at-least double all woofer(s) Vd they'll work.
For woofer(s) with large Xmax vs Sd, all PR(s) with Xmax at-least double all woofer(s) Xmax will work.
A PR max weight is said to be its Mms x3
PR Systems - tight focus with key parameters.
PR Speaker Design - thorough coverage.
I see that this tweeter is now listed as "In Stock" I'm still on the fence, hoping for some positive feedback before placing an order.SideTowers: http://techtalk.parts-express.com/fo...corundum-build
Might be a good candidate for a slanted baffle?Melby Audio - Flat Pack Speaker Kits
