Reccomendations? MTM Tl Speakers
  • Reccomendations? MTM Tl Speakers
    Hi everyone i am new to this forum and i have a ton of questions ;) i am looking to build my first set of the impossible, cheap audiophile speakers i am 16 and these will be the frst speakers i have built, i have about 300$ to spend on the drivers alone and then another 50$ to build a box out of mdf and 100$ to build a crossover. anyways, i am looking at using the dayton 7" reference woofer at 8 ohms (http://www.parts-express.com/dayton-...8-ohm--295-364) and the neodymium morel tweeter (http://www.parts-express.com/morel-m...eeter--277-060) in an MTM setup. I need these for my living room for high quality sound using vinyls and cds, only problem is because it is in the living room it will also be used for tv :P I would like to know if this would be the best tweeter in the 30$ range for classical music, classic rock, and movies. I would also like to know if this is the best woofer in the price range of 45-60$. and if not what would be? As for the interiors i need to know how to figure out the port diameter and length needed for this MTM setup, and i will need to now how to figure out the volume of air needed in the speaker box and whether a TL design would be needed? I also need to know what type of crossover to make for both the tweeter and the two woofers to run at 8 ohm total impedance? sorry to overwhelm you with questions but as i said, first set of speakers and I'm looking for a miracle.Any help would be greatly apprreciated and thanks for your time!
    Re: Reccomendations? MTM Tl Speakers
    Lost of established MTM and MLTL designs - Suggest you go with one of them. One MTM MLTL design recently listed to was the Blues MTM, available from meniscus audio as a kit - really sweet and goes plenty loud and fits in your budget. But really, lots of good design and kits available.
      Browse through the Speaker Projects gallery for lots of options and finishing styles too...
      For the RS180, have a look at the Amigas by Paul C. Really nice and works great for movies too
        I would also look at the MTM MLTL builds for Paul's Overnight Sensation MTMs here and here. You can also get the MTM kits from Menicus Audio here for $172.76 total which might give you enough wiggle room for the wood and keep you on budget or a little over.
        I wonder how many people I've looked at all my life and never seen.
        - John Steinbeck
          Thans for your input but I forgot to mention that i was looking at building a set of towers.
            You should strongly consider Dennis Murphy's ER18MTMs in ML-TLs, all the documentation is right there.
            :blues: Flat frequency response, a smooth sound power response free of resonance, careful driver-integration, and high dynamic range both upward and downward :blues:
              I suggest you read the stickies at the top. That will go a long way in your education.
              That said, your woofer choice is a common one and for good reason. You may want to look at diysoundgroup.com as well. For the tweeter, I would look for one that can cross lower, around 2KHz. Something like the Dayton RS28A or SB acoustics sb26stac. They are more money, but still reasonable and your crossover won't need a bunch of extra parts either.
                Jeff Bagby has a design using the RS180's and the RS28A he has mentioned here. There is a kit available here: http://www.diysoundgroup.com/speaker...enham-kit.html
                Several members have made this design in a tower configuration. I am seeing the finish line on my towers, it's been a long haul. This should be right in your budget and the crossover is very straight forward. This is a 4 ohm design though and I see you want an 8 ohm which may be due to your amplification on hand.
                  Tritrix might be a good option.
                    I would vote for this one too.
                    You can build them similar to these, JonMarsh's Natalie P design, wich use the same drivers.
                    "It is only Scrooge McDuck and others with a personality disorder who have money as their goal"
                      Thanks for the reply this is what i want but i need to make it 8 ohms because of , as you said, the amplification on hand:D. I was looking into Dr. K's MTM's http://www.parts-express.com/project...ject-dr-ks-mtm and i would like to build these but i need to know if they are 8 ohms and if not would i be able to convert them to 8 ohm speakers?
                        How about a pair of skull crushing 4.5 cu Dayton 8's?
                        There is even a revised more modern crossover for them too.
                        All that and a bag of chips. And you wont even need a subwoofer with these puppies!
                        Might be worth a look...
                        Kevin
                        Shaken, not stirred...
                        Classix II
                        OS MTM's
                        Digger 8 sub
                        Overnight Sensations Center Channel
                        Sprite Build
                        Wolf's PC Speakers
                        Minions III with Voxel Sub
                          Thanks for your input after more research and reading that is the design i have been led to. Great to hear your in your final stretch i haven't even reached the track! Also i have a new amp that can now go down to 4 ohms, so now just to find the cheapest place to get the parts to canada... i am thinking about using dhl and trying to get them to pick up the parts, or using a ship forwarding company, if anyone has had any experience with ship forwarding, some input would be great. Also if anyone knows the best way to get parts to canada that would also be greatly appreciated. Is the kit from diy sound group the exact same crossover as the Jeff Bagby for a recording studio?
