Grimm Audio Design Philosophy and LS1 Speaker - About $22K
Re: Grimm Audio Design Philosophy and LS1 Speaker - About $22K
Originally posted by Pete Basel View Postcraigk
I wonder if the bass is "fast" enough.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Originally posted by Wolf View PostThey had ZERO BASS at AXPONA. No warmth and seemed to only go to about 100Hz.
I heard them in a room that had subs . . .R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Originally posted by Pete Schumacher ® View PostI heard them in a room that had subs . . ."It suggests that there is something that is happening in the real system that is not quite captured in the models."
Originally posted by craigk View PostI listened to this speaker at a HiFi show in Sandton, Johannesburg, Gauteng last year. if I had $ 22,000.00 to spend on speakers, this would not be the pair I would purchase.
that anyone buy them.
I have not heard them, yet.
Perhaps they should add an adjustable BSC option in the software.
Originally posted by Pete Basel View PostMy reason for posting was to perhaps provide ideas for DIY not to suggest
Which is to say neat, too bad they apparently don't sound great but it's an interesting idea and something a DIYer could probably take a whack at for a lot less.
Thanks, yes it does provide some food for thought.
Reading it again, they show how bad the DSP DIY system is off axis, interesting that
it is the horizontal axis, so it would seem that it is caused by directionality of the drivers
and diffraction. The vertical polars are far worse as would be expected. They imply
that their system is much better but then do not show the polars!
Still it is good to see what others are doing and get some fresh ideas.
Also interesting that they prefer IIR over FIR filters probably as a result of their
preference for less aggressive filtering.
It seems at first glance, that they borrowed a lot from Linkwitz, SEAS drivers, wide
tower structure, very small sub in the base. But they are not open back dipoles so
not so similar after all.
The part I agreed with is not trying to solve reflections with DSP. There is no point as path lengths differ as you move around the room and it can make the overall power response wonky.
Same idea works with passive crossovers!
So...$22K for a two way speaker....and you still need a sub to get some sorta bass action? Is that what's being said? (Shakes head, walks away......)
Originally posted by Pete Schumacher ® View PostThe bass was so fast that it was over before the rest of the signal showed up.
Originally posted by Pete Basel View PostThanks, yes it does provide some food for thought.
I don't know how you make a bad sounding speaker with those materials....I don't know how you justify $22K for those materials.“Never ask people about your work.”
― Ayn Rand, The Fountainhead
