10" GRS subwoofers showed up today...
  • 10" GRS subwoofers showed up today...
    ...pics for now, need to get them warmed up and broken in before doing some sweeps. Built like a tank, $20 gets a lot of driver.
    The website pics make it hard to tell, but the dustcap is inverted. The motor large, bumped and vented backplate, 2" voice coil. Frame is typical cheaper stamped steel, but it has an extra roll around the inside edge of the "knockouts". Little bit of squeeze of glue around the gasket. Otherwise, looks very good.
Name:	DSCN1967 (Medium).JPG
Name:	DSCN1966 (Medium).JPG
    I happen to have a pair of cabinets out in the garage that I have been looking to repurpose for some time now. These will be perfect.
    Re: 10" GRS subwoofers showed up today...
    They look like the kind of stuff Rockford Fosgate sold with a Punch logo for $150 each 20+ years ago.
    What size cabinets are you planning to put them in? IIRC, they model OK in as small as 1 cf each sealed and stuffed, but really modeled well in 2 cf plus.
    | there is no spoon... |
      Well... if I measure them to be very close to advertised T/s, I am going to do this with them:
      This is modeled using the Dayton 250W plate with the 6db of boost at 30Hz enabled, and 80Hz lowpass added. 3" x 16" port. F3/6/10 of 29.4/26.6/23.8
      No exceeding of Xmax, port velocity under control. Me likey.
        [ATTACH=CONFIG]52916[/ATTACH]
        [ATTACH=CONFIG]52917[/ATTACH]
        [ATTACH=CONFIG]52918[/ATTACH]
        these look like they could be a nice find.
        craigk
          Hopefully the design works out well -- definitely wouldn't be my first choice based on T/S parameters: http://www.parts-express.com/grs-10s...4-ohm--292-482
            Broke in for 15 minutes at 30Hz at close to Xmax.
            Very impressed with the consistency between advertised and measured. The differences between the two are well within tolerances, and attributable to different test methods.
            56.8L = 2ft^3
              Off topic, but shouldn't that equation be written as:
              [(Vas/Vbox)+1]^.5=a or sqrt[(Vas/Vbox)+1]=a
                I'm pretty sure you are technically correct. I should probably fix that...
                  [ATTACH=CONFIG]52921[/ATTACH]
                  56.8L = 2ft^3
                  Nice! That's a lot better then advertising Qts in the .4 range when they are really .6
                  http://jaysspeakerpage.weebly.com/
                    Very impressive tolerances, indeed. Not much worse than changing your design after drivers arrive because they measure so far out of spec...
                      That looks like a pretty good deal for a low-reaching sub. $20 is a super-nice price if it does what it looks like it will do. I'm tempted to purchase a few for making mid-size subs as gifts for friends/family.
                      How was it when you were breaking it in Johnny,... was it mechanically very noisy? I see what you're saying about the openings in the basket being rolled in -- which I would think would add some additional stiffness. And probably make it sharp too! Your pics were a little more revealing of surface details, PE's pics of speaks are often kind of dark.
                      Thanks for posting about this.
                      TomZ
                        Glad these are looking as good as they promised in the first thread, thanks for testing and sharing JR!
                        Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
                        Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio Club
                          Kind of a good looking cone. Like that big vent too.
                            Hopeful they can make 1000 Hz x-o....
                            John H
                              Seems like it could be a good low power / larger box sub option. Modeling in a 2 cu. ft. sealed PE knock-down cab with 50% fill and 100W amp yields 42 Hz / 35 Hz / 28 Hz (F3 / F6 / F10) with a Qtc of ~.86 (approx. 1.8 cu. ft. net after subtracting woofer basket and amp). Should actually handle close to 175W before reaching Xmax in this box.
                              FR Graph. Red line is anechoic, Blue line is w/ room gain.
Name:	GRS SW10-4 FR.png
                              Cone displacement.
Name:	GRS SW10-4 CD.png
