DIY Flat Panel Speaker Love
  • No, but I have used something similar from Lowes called coroplast. I didnt care for it. If you do decide to try that carbon core I would suggest the 6mm thickness.
    • These are my higher end DML panels playing. DML - YouTube​
      • Originally posted by Unbiasedsound View Post
        Nice job. To me, the prices on the exciters have reached a level where the cost/benefits don't make sense. Too bad.
        • Thanks. Yup, the prices for most exciters have almost doubled in which I cant afford it anymore so my future development of DML projects are put on hold until the prices come down or some how I become rich. lol
          • Originally posted by Eipromb View Post
            After doing a ton of reading and lots and lots of trial and error, I managed to get my version of a DML working.
            Here are pics, but please ignore all the dust everywhere! It’s a mess in the den.
            I'm inspired by your pics! I've got some 1in XPS boards and a new membership to a fab lab. I'm looking to learn how to CNC and this is a great opportunity.
            I've drawn up a couple of prototypes on fusion360 that are based on the golden ratio. Both have a 75mm circular mount area with markings for a 34mm exciter. The resonant surface is set to 12mm thick.
Name:	DML rect.2.png
ID:	1491577 Click image for larger version
Name:	dml shell.png
            For all the DML vets and experts, please feel free to toss out any suggestions/comments that may improve the design. I've got plenty of questions, for example:
            • straight or tapered edges down to the resonant surface?
            • why is the exciter mount area extruded, for extra strength?
            • what is the optimal thickness for the resonant surface. why 12mm/0.5"?
              • should the resonant surface be flat?
              • sculpted in 3D with additional bracing?
            • would it be better to mount directly on the 12mm resonant surface? or cut it down to something in-between?
            • what is the optimal size of the exciter mount area? I gave it a 20mm border for no particular reason
            • for the rectangular cut:
              • the exciter is centered at 61.8% of the X/Y dim of the resonant surface, this is the golden mean ratio.
              • the border is 1/8 of the short length of the resonant surface
              • the corner radius is 1/4 of the short length of the resonant surface
            • for the shell cut:
              • the shell curve is also based on the golden ratio/spiral
              • I have no idea how to manage the boundary conditions between the beginning/ending points of the spiral. a straight line was drawn, but I'm open to suggestions.
            • has anyone considered mounting the "frame + foam" against the inside edge?
            • what is the purpose of the "spline"?
              • To anchor the exciter housing such that more energy is transmitted to the resonant surface?
              • what should the spline be anchored to? the surface anchoring the foam strips?
            Toss out your theories and I'll try to incorporate them before I cut. My XPS boards are 405mm wide, so that will limit the size of the prototypes.
            • What gave you the idea for that particular shell shape?
              I have mounted the foam to the frame on the inside edge before as this is how its done in one of Bertagnis designs. This will allow more vibration waves to travel to the outer edge giving it a more holographic image as sound will be radiating from the front/back as well as the (outer edge) sides almost like a ominipolar. Mounting the foam to the frame from the outer edge will have less holographic image because sound will be radiating mostly from the fron and back with less vibration reaching the outer edges. This is one reason if mounting on the outer edges of the panel I suggest using 1 inch strips of foam with 1-2 inch gaps inbetween so some sound can come through the gaps, again personal preference.
              A spine is to hold the exciters magnet in place so that it does not sag and to give it something to push off of to transmit more energy to the panel the same way a conventional cone driver uses a basket to hold the magnet in place. Without a spline at high excursion levels the magnet will rattle because there is nothing holding the magnet in place. Bertagni knew that if the magnet was not held in place the voice coil would sag under the weight of the magnet as well as rattle because there is nothing holding it in place to push off of which is similar to a BMR drivers design that is built more like a conventional cone driver. Adding a spine will change the sound a tad bit making it sound more prominent then diffused again its personal preference.
              The spine should be mounted to a frame. Look at photos of Bertagnis speakers on the web and you will see what I mean.
              ​Click image for larger version
              I believe Yamaha used the shape of bertagnis panel design to create there elephant ear shaped speakers. If you notice the "EAR" shape in that pic it has no sharp corners but more of a rounded shape. This is the reason for ROUNDING the corners. Sharp corners will add sharp peaks in the high frequencies. This is the reason most conventional cone drivers are shaped like a circle as there are no sharp corners which can cause peaks at certain frequencies especially the mid to high frequencies.
                For the shell shape, I was following a golden rectangle tutorial on fusion360 and then extruded the outline to fit the XPS foam. I suppose the intuition is that the exciter has a different resonant length for each polar angle--maybe you get a smoother freq response? Of course, you're right about the sharp angle at the boundary. I didn't know what to do with that.
                I like your explanation about the intuition for the spline and the free-edge radiation. but what is the mindset for the various shapes milled into the examples you have shown? and what is the intuition for the ultimate thickness of the milled section of the XPS? I chose 12mm randomly...
                • Technically the outer shape of the panel is a rectangle. Rectangles have corners so to isolate the corners a channel was made to (prevent) lessen the vibrations from reaching the four corners of the panel.
                  For EPS and XPS 12mm (1/2inch.) is a good choice. Thinnest I have used for EPS is around 6mm (1/4inch).
                  • Also that picture I posted above of the Bertagni sm100 speaker is a 2 way as it uses a 16mh capacitor for the exciter in the upper corner, while the exciter in the middle is used for the lower frequencies. There is no inductor for the low frequency exciter, instead Bertagni uses some type of glue/damping adhesive to tune it for low frequencies. 16mh capacitor is around 1200hz so I am assuming he tuned the low frequency exciter to play around 1200hz.
                    Those small brown dots are basically weights and act to reduce waves from reaching the high frequency exciter.
                    Also the Bertagni panel has various thicknesses throughout the panel with grooves and channels to control and tune it.
                    Bertagni's panels are a step up (maybe 2 steps up) from the standard DIY DML panels.
                    Bertagni was ahead of his time in bending wave technology and one of the pioneers that I base some of my techniques on.
                    Right now I am working on my new Flagship design and my new design will blow Bertagni speakers out of the water. LOL This new design is even better then the two previous videos I posted. If I have time I might post a video of my new flagship design.
                    • I finally figured out the CNC and here's a first draft. The internal surface is a golden rectangle at 32x20cm and milled to 12.5mm thick. A 25mm border with rounded edges remains. I also have a plain rect of the same size, both treated with a 50/50 PVA glue coating. Compared to the plain rect, the milled version definitely sounds clearer and brighter. But I want to be able to quanitfy these results as I continue experiments on larger panels and different shapes.
                      What is the best practice for creating freq response charts for speakers? I have a Dayton iMM-6 callibrated microphone (https://www.parts-express.com/Dayton...ophone-390-810) and an iPhone with StudioSix AudioTools/FFT analyzer. But I'm not sure what settings to use to get results that are easily comparable with what I see on the web.
                      Here's what I have:
                      1/3 octave graph smoothing
                      Full Range FFT
                      Flat Plot (vs A-wtd/C-wtd)
                      Hamming window (vs none/Hann/Blackman)
                      Mic distance=1 meter
                      Generator=white noise (vs Sine/Square/Pink)
                      Does anyone have better suggestions?
                      • Yesterday I spent my free time making a mini (14inchX10inch) 2 way DML panel which is similar to Bertagnis SM 100 speaker shown in the above pics in post external xo
                        Also the prime rib was so delicious. lol
                        • DML mini modified Bertagni. - YouTube​
                          • Wow my 2 way Bertagni type mini panels sounds better then I expected, use headphones.
                            DML-2 - YouTube​
                            • DML Tower type. Superb vocals.
                              DML Tower Type - YouTube​
                              • DML Tower Type modified.
                                DML Tower Type 2 - YouTube​
