Re: DIY Flat Panel Speaker Love
Comparing the freq. resp. of the DAEX58FP to the better sounding DAEX25FHE-4 you can see that the DAEX58FP does have more extended bass response which may be responsible for some of its boomy|sluggish performance???
DAEX58FP - 1. close miced' 2. from the listening position
DAEX25FHE-4 - 1. close miced' 2. from the listening position
note : Ignore the output levels as they did not receive the same signal level.
Look at the differences between the 2 DAEX25FHE-4 responses. There doesn't seem to bee as much difference between the 2 measurements. Then compare the DAEX58FP measurements... the close miced' freq. res. shows noticeably more bass output?
I wonder if the increase in bass response is panel "noise"? That may explain boomy, fuzziness when listening to the DAEX58FP... wouldn't rule that out.
Unfortunately I have already tore down the crappy sounding DAEX58FP's off the panels so no more troubleshooting and comparing can be done. :(
Curious what would happen if I EQed the new panel response to match the DAEX58FP's???
