Originally posted by Kornbread
View Post
I'll have to try the panel closer a wall like you mention. That should be more realistic for what anyone would normally do with a large panel. I was using a relatively short cord in the middle of the room during my quick "test" so I'm curious how different that might sound.
I'll probably also need to grab a small section of plywood or something to let the screws anchor tight into something through the other side of the XPS...and see about some kind of temporary hanging method for the panel that won't put holes in the wall or ceiling.
Originally posted by Unbiasedsound
View Post
This thread is making me excited to dig out the little transducer collection that I haven't played with in quite a while. I think the cheaper DAEX25FHE-4 was suprisingly decent for the price...and it looks like it might sound similar to the Thruster/DAEX32EP-4 albeit at 24w VS 40w power-handling.
I remember being pretty underwhelmed with the much more expensive DAEX25SHF-4 (though I don't think it was $40 when I bought it). I thought the HDN-8 was kinda garbage and didn't care much for the "SquareFrame" models I tried for whatever that's worth.
EDIT: Looks like I still have;
DAEX30HESF-4 (easily the most robust-looking of any fullrange exciter I've tried, with thicker tinsel leads and reinforced connection to voicecoil),
DAEX25FHE-4 (looks like a cheaper 30HESF-4, but seems to lack some of the HESF's sensitivity and also might lack some of the HESF's bass and treble),
DAEX25SHF-4 (still looks cheaper and more fragile than the HESF and mostly just sounds louder in the mid-frequency...like a louder 25FHE at 4X the price),
DAEX58FP (sounds better than I remember and no exposed+delicate tinsel. Thought it was a little quiet but then realized it's 8ohm...not bad).
I think the HDN-8 and coin-type low watt exciter I had broke. If I remember right, the HDN-8 partly fried (pushed a little too hard when it never got nearly loud enough) and the coin-type got slightly torn/damaged trying to seperate it from a surface it was stuck against with its strong adhesive.
