Hi all!
I'm building an IDS 25 clone out of 25 Fountek FE-83 drivers.
I wrote another thread regarding what to do with a couple of those little toys, so I decided to go big and build an IDS-25 clone (by Roger Russell).
It has been quite a tiring experience. I'll post pics later, but I guess I have invested close to 20 hours wiring, preparing drivers and making holes on the cabinet, etc. (I didn't build the cabinet, I had it build by someone else). I'm still 2/3rds of the way there before I can finally wire the speakers and start working on the transfer function for the EQ.
I knew this would be a lot of work, but never did I think it'd be so much! It really takes some special dedication.
As it is, the only thing that worries me is - whether the drivers can do real bass. I don't want to use a subwoofer - I want a full-range line array. If I use a sub I'll have tons of integration problems, since the subs will be point sources and the speakers are line-arrays. Everything will sound OK only in one point in my living room.
The thing is, if distortion is too high I won't be able to use the FE-83s that down low... I have this feeling that distortion at 40 or so Hz may be too much and they could be unusable. Something I learned while building the little 3" speaker by Zaph - doesn't matter if the speaker can do 3 mm Xmax if the non-linear distortion profile sucks. :(
Current plan is to use a sharp filter at 30 Hz. I'll start with a UltraCurve based EQ, and then move to a digital MiniDSP unit.
