Full range line array for home theater fronts?
  • Full range line array for home theater fronts?
    I was thinking that it would be really easy to build a nice pair of line array speakers to act as fronts for a home theater. Maybe 5 full range drivers in each?
    Any thoughts one this one? I am a noob to DIY speakers, but I have been reading like crazy.
    I did build a small pair of full range speakers but I am wanting to take on some real challenges with speaker building and woodworking.
    Any pros/cons of small line arrays?
    Thanks in advance!
    Re: Full range line array for home theater fronts?
    A full line array will generally consist of more than 5 drivers.
      5 drivers is not a good number of drivers to work with in a line array. Usually an even number of drivers works better unless you are also integrating shading into the array. However this is normally not done in such a short array as you propose.
        I believe he is talking about a full range line array, not a full line array.
          Yes I am. I am thinking of 5 full range speakers wall mounted next to each side of the TV.
          Am I wrong calling this a line array?
            Using an odd number of drivers isn't really possible, or intelligent if it is possible. The trick in arrays is to use series/parallel wiring so that you can maintain a 4 or 8 ohm load on your amplifier.
            I just recently built a pair of small arrays similar to what you're describing, using 8 drivers per side. I really like the performance, and when mated with a subwoofer they work perfectly for Theater.
Name:	Array Picture.jpg
              I use line arrays, though 2-way, not with full rangers. You could use full range if the listening distance is far enough out so that the high frequencies have coalesced into a single wave front. They have the advantage of high sensitivity and controlled vertical directivity. Just stay with a wiring friendly number of drivers.
              Nine drivers allows the array to have the same impedance as a single driver. You can't do that with eight drivers.
              Usually, but even two drivers gives the main benefits of an array, increased sensitivity and output with reduced vertical dispersion.
              www.billfitzmaurice.com
                You got me Bill! Bah! :p This is true. Damn multiples of 3. The rest of the idea remains the same, where you need to be able to have matching series/parallel groupings.
                  Ok, so 6 then and a sub would give me a decent result sounds like.
                  I understand the series wiring implications. Thanks.
                  Any recommendations for good reasonable priced drivers here at PE?
                    The Fountek FE83 is $7, and the Vifa TC9 is $11 and slightly more suitable.
                    Here's a link to the FE83s. You'll want 25 (odd numbers are fine as long as they're the square of another number) per side, and it looks like stereo subs at 200hz are recommended (the RSS390 sounds reasonable.)
                    http://techtalk.parts-express.com/sh...n-a-line-array
                      You'll want 25
                      Why so many?
                      I wouldn't run subs higher than 100Hz, so I wouldn't do mains incapable of going to 100Hz.
                        Why so many? I wouldn't run subs higher than 100Hz, so I wouldn't do mains incapable of going to 100Hz.
                        Less might work - the design in question uses 25.
                        As for stereo subs, they'd really be functioning more like woofers in this application - distortion starts to increase pretty heavily at 200hz, although you'd probably be correct that 100hz is far more appropriate for home theater use.
                          I have measured the tc9's and used them in one design. They sound fantastic but I would not run them below 200 or so for best distortion performance.
                            Bill F. has this design. There are cases of these old Sony speakers still available as well as bags of Onkyo tweeters. Why, I have some myself. A Bill F. forum member did a nine speaker version and was very pleased, IIRC.
                            http://www.billfitzmaurice.com/SLA.html
                              A nine driver version would probably be the TLAH, not the SLA. Here's a recent example:
                              http://billfitzmaurice.info/forum/vi...p?f=30&t=22468
