SB Acoustics SB19ST-C000-4 Tested
  • SB Acoustics SB19ST-C000-4 Tested
    I know Jeff B. showed a quick and dirty preliminary test, but I figured I'd do the whole nine yards anyway and post my results here. It does indeed measure like an incredible tweeter, even more so considering the cost.
    I just grabbed a piece of 1x8 pine I had lying around and routed out a small test baffle. I first consulted Jeff's Boundry and Diffraction simulator for the optimum position for flat on-axis measurement. The piece of pine is 7.25" wide and 13.5" tall. The center of the dome is exactly 2.5" from the top and 4" from the left side (in this image). This position yields a flat response, less than +/- 1db across the treble spectrum on-axis.
    2nd and 3rd order is just as clean as Jeff's quick and dirty test. I added three voltages here to show how it scales. It looks good for a very low crossover considering the small size of the dome. If you weren't worried about extreme SPLs, I could see a steep crossover as low at 1800. The critical thing I see from the sharp incline of the distortion below 1500 hz is that you'd want the tweeter response down 20 db or more at 1 khz (at the minimum).
    How about the off-axis?
    Damn near perfect out to 30 degrees, terrific. The odd changes in response here are due to the offset of the tweeter on the small baffle. You can see the 2 to 3khz get a baffle boost as we move off-axis and a ripple form above that. Even with all that considered, the tweeter on this baffle is performing awesomely.
    Hands down, this looks like a great tweeter at 50$ and an unbelievable buy at 18$. All that is left now is to listen and confirm...
    Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
    Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio Club
    Re: SB Acoustics SB19ST-C000-4 Tested
    Oh, and as a side note: the rise at 20 khz and sudden drop-off is due to the digital filter on my Onkyo receiver.
      It should have a "pure audio (or some such thing, I forget)" mode, which essentially turns it into a pre-amp and amplifier only. I never had any issues with my 603 or 808 with a cutoff like that when using that mode.
        The best I have is "direct" which bypasses all processing. That is what I use to measure. However, the digital filter still seems to be in place (for HDMI sources anyway).
          Based on both measurements I have seen now, 2K is definitely an option.
            Ahhhhh bad, naughty Jason - use analog inputs for measuring.
              Maybe I am looking at this wrong, but that impulse graph does not look so good. Maybe there is a reason for it.
                No waveguide needed for this puppy. The key is going to be to match the directivity of the midwoofer which will dictate either the size of midwoofer or the XO point. This tweeter screams WWMT threeway tower.
                  I'm pretty stoked about my iron driver build right now
                  http://jaysspeakerpage.weebly.com/
                    Jason, I think there may be an issue with something in your measurement chain. Every distortion measurement you have posted shows a large peak in 3rd order around 6-7khz.
                    -Kerry
                      I was wondering when someone was going to point that out. I noticed it, wondering if it has something to do with the 21 khz peak (21 / 3 = 7) which might make it another Onkyo issue. I'll know more when I switch it out for a another/better amp soon.
                        I'll have to investigate further. I just hooked up the test gear and discovered a strange inconsistency. The HolmImpulse setup says 96khz input and output stream. My receiver DAC can handle that, the UMIK can't (limited to 48khz). I'll correct that setting and see what shakes loose tomorrow.
                          Here ya go
                            Lowell, your measurements appear to be headed toward a spikey at 7k as well.
                              Im not sure I would call that a spike.
