MFW driver
  • MFW driver
    I all, I have left one of the mfw driver, I'd like to build a vented enclosure with the same spec of the original cabinet, but with a round vent.
    If I am not wrong it shoud be 3cf net, with a port of 4" and length of circa 14".
    Can anyone help?
    Marco
    Re: MFW driver
    link?
      Re: MFW driver
      IIRC, it was a 15" Eminence sub driver that GR research did a buyout sale with. Old AV123 stuff. I poked around but didn't find any specs. Airliner could probably find the specs, there were several projects done with it.
        Re: MFW driver
        see attached for specs...
          Re: MFW driver
          That "works" (I'd probably go longer, up to 18" long). But then, I'd use a pair of 4"id port tubes, each one being 38" long, but that's just me.
          He!!, if it were me, I'd just go 6cf w/a pair of 4"ports that were 20" long (each). Probably good for another 8Hz, at least.
            Re: MFW driver
            I have 4.5cf gross, the original design had similar dimension with a long slot port, I would reproduce using round flared port
              Re: MFW driver
              Is your net > 3cf then? If so, I'd probably change the tune a bit.
                Re: MFW driver
                Where would you bring the tuning freq? 25?
                I forgot to tell both driver and vent should be downfiring
                  Re: MFW driver
                  see post 7?
                    Re: MFW driver
                    Hi, yes I saw it, that's why I am asking the tune you suggest
                    Thanks Marc
                      Re: MFW driver
                      I don't really care what your gross is. I'd have to know your net cf to give a credible answer.
                        Re: MFW driver
                        Sorry, now I got it! I made calculation again and it is approx 4cf.
                        Marco
                          Re: MFW driver
                          Fb = 22Hz. For 4 net cf, I'd use a pair of 4"id by 32" long port tubes.
                          Should make it down to 30Hz w/out TOOO much "lift" (which it still has, between 50-60Hz).
                            Re: MFW driver
                            Thank for your help Chris
