Ok I know it sounds odd but I'd like to conduct some kind of listening test where I can, while having the music play, switch between two amps or receivers and have the output go to the same set of speakers? If I can do this via a remote, that would be good. I've seen plenty of speaker switch boxes but that doesn't help me. Neither does an input selector because the speakers wont switch over.
Its basically something to switch between two amps which have been adjusted to the same volume level and seeing if there is much or if any audible difference between the amps themselves. Better if a friend connects the inputs and doesn't tell you what you're switching between (ie source 1 or 2). Any help appreciated.
Bad diagram provided.
