Re: I theorize: 'Synchaeta'....a Minimus 7 revamp...
Here's the pic of the patch:
Sorry for the fuzz- I was also trying to get the picture of the rubber floor tile glued to the side walls. This adds mass and lowers the Fb of the panels since they are 3/16" thick.
Xover in position:
I did not solder the resistor to the tweeter, as the leads on my used 15 ohm were not long enough. The space between the terminals is long enough to fit the resistor though. 3" hole saw for the boards. I had to go 'off-board' to get it all on there.
Mounting hole yet to be drilled marked by the blue dot, will allow installation through the tweeter hole with a simple screw:
All poly'd up:
Wall mount included to keep true to the original:
I have yet to build the other and solder both xovers, install the terminals and stuffing, and then apply seals for the drivers and torque them into place.
I should have them playing this weekend,
Xover in position:
All poly'd up:
