Re: Any issues not using ground lead on potentiometer?
Okay, so my little 'shielding' experiment didn't have a chance.
The heatsink is glued on there, but Rory in his statement on the Q&A section said that the markings on the chips were 'obliterated' before gluing on the heatsink, so I guess we're outta luck there.
I'm beginning to think that this little board may have problems.
Okay, that makes sense, what should I ground it to, the negative terminal on the power supply incoming? I can drill/tap a screw on the alum. plate to ground things to if it helps, no problem there. I would ground the pot body and what else would you suggest grounding? The amp board is only touching the alum. plate where the main volume potentiometer is bolted to it, but the board itself is basically right next to the alum. plate. The red piece of electrical tape is there to prevent any direct contact between the board and the alum.
If I wanted to 'ground' the amp to the board, how would I even do it? I don't see metal showing on any of the mounting holes on the amp board. The only place I can think of to ground it would be on the negative terminal of the power coming in.
I'm assuming that the main volume pot mounted on the amp board although it is metal, would not actually be conducting anything to anything else.
So again, it works fine with a jumper in place, no real noise. The only noise is when I try to wire in a potentiometer... and again to reiterate, the same thing is happening with both the bare naked board and the one mounted to the alum. plate.
I'm a bit bummed, this little board is quite nice otherwise. But without a way to adjust the sub volume, it's not going to fly in my book. Wonder why they just didn't build it with the sub pot built in?
TomZ
Originally posted by 1100xxben
View Post
View Post
Originally posted by PWR RYD
View Post
TomZ
