I just finished a Bose type line array system using Celestian AN2775 speakers. They sound dead, no high end. I used acoustistuff loosely stuffed in the cabinets, could it be causing the highend loss? If not does anyone have any idea's? The frequency response on the 2 3/4" Celestians is 160 to 19k. Thanks
Line array problem
Re: Line array problem
Originally posted by Spartacus View PostI just finished a Bose type line array system using Celestian AN2775 speakers. They sound dead, no high end. I used acoustistuff loosely stuffed in the cabinets, could it be causing the highend loss? If not does anyone have any idea's? The frequency response on the 2 3/4" Celestians is 160 to 19k. Thanks
Acoustistuff should not impact the driver's high frequency response much. More than likely the drop at high frequencies is due to driver directivity and comb filtering effects between drivers. These can combine to shelve down the top couple of octaves.
Originally posted by Spartacus View PostI just finished a Bose type line array system using Celestian AN2775 speakers. They sound dead, no high end. ..."Not a Speaker Designer - Not even on the Internet"
Originally posted by Jeff B. View PostAcoustistuff should not impact the driver's high frequency response much. More than likely the drop at high frequencies is due to driver directivity and comb filtering effects between drivers. These can combine to shelve down the top couple of octaves.
John, take some time to read and digest this article from Dr. Griffin, and you'll gain some pretty good understanding of line array designs:
http://www.audioroundtable.com/misc/nflawp.pdfSome people are addicted to Vicodin. I'm addicted to speaker building.
LM4780 Parallel Chipamp
Sonata Soundbar Project
We have a large CBT array at our church using similar size drivers and equalization is needed to smooth out the response. Even at that it still is limited by the horizontal coverage.
I strongly suspect a wiring or crossover problem (if you used a crossover). These should NOT sound dead or flat. How many drivers per side and did you wire them series- parallel? Array wiring is tricky and there is not much info on the web that actually diagrams how to wire various numbers of drivers (I know of one source). One easy thing to do, although this will not affect high frequency much if at all, is to connect a single battery (AAAA,AAA,AA,C, D) to your speaker wires just to make sure all cones either move in or out together, you should not have some moving in while others are moving out, you could also measure resistance across your speaker input terminals, I would think somewhere between 3 and 15 ohms would be expected. I'm sure others will chime in, the more we know the more we can help.
Originally posted by Spartacus View PostNo eq as of yet, I've got two columns stacked with 18 Celestians total. The columns are 4" wide, 5" deep and 30" high.
They are wired in series in groups of three and then those groups in parallel to result in an 8 ohm load for each of the two columns. There is a 99 micro farad capacitor installed inline on the positive wire at the input jack.
This is a fascinating thread to me because I had an unfinished project that used two of those per side and I ended-up selling it off.
Now having completed some speakers with single Faital 3FE22's, I have a different perspective on these small, full-range drivers.
In the case of the 3FE22, the response curve makes it seem like I'd have a pretty peaky top-end when measured on-axis. I can say that is absolutely not the case, they roll-off pretty quickly above maybe 14-16k. I'm still not clear if the difference in high-end response is due to the baffle size or something else.
When I was going to use the two Celestion drivers per side, I was told here about comb filtering and I didn't want to have to experiment with crossovers so I "got out."
But seeing as you've gotten considerably further, what I'd do in YOUR case is I'd try disconnecting everything except a single driver and take a listen and see if it still sounds "dead." If not, then the crowd here is likely correct and you're likely experiencing the comb filtering they're talking about.
Oh and one more thing, I originally started with 3fe25 drivers in different enclosures, and then switched to a new project with the 3fe22. And in doing so, I thought my newer project sounded pretty lifeless. But breaking-in the drivers made a world of difference. You'd think that a new, stiff driver would be brighter but I actually found the opposite to be true.
