Hello Community. For those currently planning upcoming builds, your driver options are expanding. In addition to the soon to be released Satori 187mm MW19p woofers, new 8" subwoofers, and neo-magnet TW29RN tweeters, SB Acoustics will be adding a 'DX25-esque with copper' tweeter, model SB29SDC, and the Carbon Fiber/Rohacell coned 6" SB17CRC35-4/8 mid-woofers to the lineup. The preliminary partial parameters for the 8 ohm driver include; an Re-5.7ohms, Fs-29hz, Qts-.35, Vas-40ltrs., Sd-118cm2, 2.83v/1m-87db, and Xmax-5.5mm. Additional driver sizes and data are forthcoming. Also, we should soon see all-new members of the Tymphany/Peerless HDS family of drivers equipped with massive under-hung, FEA-optimized motors, replete with copper-capped pole-pieces and shorting rings. A variety of diaphragm materials and driver sizes are on offer. I will provide further details upcoming..........
Carbon/Rohacell drivers from SB Acoustics-more!!
Re: Carbon/Rohacell drivers from SB Acoustics-more!!
Originally posted by olu78 View PostHello Community. For those currently planning upcoming builds, your driver options are expanding. In addition to the soon to be released Satori 187mm MW19p woofers, new 8" subwoofers, and neo-magnet TW29RN tweeters, SB Acoustics will be adding a 'DX25-esque with copper' tweeter, model SB29SDC, and the Carbon Fiber/Rohacell coned 6" SB17CRC35-4/8 mid-woofers to the lineup. The preliminary partial parameters for the 8 ohm driver include; an Re-5.7ohms, Fs-29hz, Qts-.35, Vas-40ltrs., Sd-118cm2, 2.83v/1m-87db, and Xmax-5.5mm. Additional driver sizes and data are forthcoming. Also, we should soon see all-new members of the Tymphany/Peerless HDS family of drivers equipped with massive under-hung, FEA-optimized motors, replete with copper-capped pole-pieces and shorting rings. A variety of diaphragm materials and driver sizes are on offer. I will provide further details upcoming..........
An underhung with all the goodies HDS sounds very intriguing.--
"Based on my library and laboratory research, I have concluded, as have others, that the best measures of speaker quality are frequency response and dispersion pattern. I have not found any credible research showing that most of the differences we hear among loudspeakers cannot be explained by examining these two variables." -Alvin Foster, 22 BAS Speaker 2 (May, 1999)
Competition is usually very good for the consumers.
Looks like a new family of instant classics.
Tangband W6-sub
Originally posted by fdieck View PostCarbon Fiber/Rohacell.... They have gone over to the dark side I fear.craigk
Start saving your pennies. ;)Kenny
http://www.diy-ny.com/
Originally posted by fdieck View PostYes that must be it... Too bad you are stuck with those mushy Scan Speaks.. there have been some really good Rohacell drivers in the past. the Focal W series is very good.
craigk
I am just giving you a hard time and I love your Scan Speak two ways. I have one of those woofers I got with a bad surround that I fixed. I am not read to give up on paper as there are many paper drivers from Viva and SB Acoustics that are drop dread good. I think there are some very good non paper drivers like the Scan Speak damped fiberglass Discovery series cones. I have heard several composite cones that I don't like, some of the Etons come to mind. Also my pockets are only so deep.
Originally posted by fdieck View PostI am just giving you a hard time and I love your Scan Speak two ways. I have one of those woofers I got with a bad surround that I fixed. I am not read to give up on paper as there are many paper drivers from Viva and SB Acoustics that are drop dread good. I think there are some very good non paper drivers like the Scan Speak damped fiberglass Discovery series cones. I have heard several composite cones that I don't like, some of the Etons come to mind. Also my pockets are only so deep.craigk
Originally posted by timw View PostIs it the Eton cones or the motors you don't like?
