I have a couple of woofers in boxes that I can't remove because they are too tight. Any suggestions on how to remove them?
How to remove woofers that are too tight in the box?
Re: How to remove woofers that are too tight in the box?
I'm not sure what you mean by too tight in the box, but threading a bolt through one of the mounting holes and gently tightening it will usually pop the woofer off the surface.Francis
Originally posted by rhodesj View PostPlug any ports, then play some low freq sine waves so the drivers have some excursion, see if they work themselves loose?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.diy-ny.com/
If all of the above suggestions fail, as a last resort
The Husky 4-Piece Precision Pick and Probe Set features 6 in. tools outfitted with ergonomic grips that allow firm hold and superb controllability. These affordable instruments are useful for positioning
You will likely have minor damage to the surface around the woofer hole, but it wont be anything that cant be repaired.
Originally posted by rhodesj View PostPlug any ports, then play some low freq sine waves so the drivers have some excursion, see if they work themselves loose?I'm not deaf, I'm just not listening!
Drill a small hole directly behind the woofer that is stuck and use a dowel wood or metal depending on how bad it is. After you try the loose screw and low frequency trick... I would try all low frequencies starting at the bottom.‘There are none so blind as those who will not see.’
Originally posted by johngalt47 View PostI have a couple of woofers in boxes that I can't remove because they are too tight. Any suggestions on how to remove them?
