Hi Everyone,
I'm looking for some help with the crossover settings and general setup of my sealed Ultimax15 in my living room 3.1 home theater setup. The subwoofer / box combo is the Ultimax15 with sealed 3.0 ft^3 box knockdown kit from parts express, stuffed with 3lb of polyfill as recommended. The system setup right now is a Marantz SR6009 receiver with the LFE channel connected to a new Crown XLS 1002 amp. I have the Crown set to high input sensitivity (0.775V) to match the consumer pre-out voltage from the receiver, and have the sub connected as 4 ohm bridged load on the amp to get 1100W. I have the LFE low-pass crossover in the receiver set to 120 Hz, and currently NO additional crossover setup in the crown amplifier (have the option of additional low pass, high pass, or band pass within the Crown itself). The subwoofer has been calibrated in the system by Audyssey using "12-noon" gain settings on the Crown amp, and this resulted in 0 dB of additional gain being added from the receiver's channel level options. The subwoofer is physically located in the corner of my room, which was the best spot available via the "subwoofer crawl" method.
My question is whether I should leave the crown amp as no-crossover ("full range" signal from LFE channel), or add an additional high pass filter to protect the subwoofer? The Crown provides options for high pass with frequencies starting as low as 30Hz... and the F3 = 35Hz for that subwoofer in a sealed setup at 3 ft^3.
I am concerned a bit because I was watching Netflix last night (specifically Wet Hot American Summer - First Day of Camp, episode 4, the scene where toxic sludge starts to expand out of the hole), and ran across some pretty raucus LFE content that I believe made the subwoofer distort. I did not increase the receiver LFE channel level over 0 dB, but the bass dipped into very low frequencies and made a loud flapping sound rather than any controlled bass reproduction.:eek: I assume this was the subwoofer, not my house shattering around me... but it was dark, and I wasn't watching the subwoofer cone to see if anything looked amiss! If I added the high pass filter at 30 Hz on the Crown amp, would that safeguard me against this kind of thing, or would that just rob me of additional bass content that I can safely use otherwise?
Thanks in advance!
Thanks in advance!
