I've decided to replace the tweeters in my less-than-stellar Sony tower speakers. The originals are 6-ohm and have a 1uf capacitor on the positive wire.
I've decided to go with these Beston 6-ohm ribbon tweeters, and I need an 18dB 3rd order crossover at roughly 3500hz.
According to a crossover calculator I found online, I need 5uf and 15uf capacitors and a 0.2mH coil to achieve 18dB 3500hz crossover point with a 6-ohm driver.
The reason I'm posting is because I'm not 100% sure I can trust the calculator. I was curious what the crossover point on the originals were, so I started inputting crossover values until the outcome was a 1uf capacitor. According to the calculator, the original tweeters have a crossover point of 25,000hz with a 1uf capacitor at 6-ohms, which obviously makes no sense at all. Is the calculator borked?
Does this look right?
Because this sure doesn't.
