Can't clamp down my circular saw cutting guide, ideas?
  • Can't clamp down my circular saw cutting guide, ideas?
    So I made these awesome circular straight edge guides and do my first cut which is the long rip to cut the side and front panels to height. I then went to cut the first 7.5" wide baffle and there is no way for me to clamp the jig to the mdf. I feel a little stupid right now. I would need some super long clamps or I'm thinking about just screwing down the guide to the mdf and filling the at most, 2 holes during prep. Anyone run into this?
    Re: Can't clamp down my circular saw cutting guide, ideas?
    Pics?
    _____________________________
    Tall Boys
    NRNP Computer Sub
    The Boxers
    The Hurricanes
    The Baronettes
    Conneccentric
    UX3
        I already see what I had to do for smaller pieces of wood. I needed to make both sides of guide a straight edge so that I could turn the saw around and ride the skinnier side along the guide. The problem lies in the fact that the saw motor hits the clamps. The only place I could clamp would be on the left side passed the guide bit as you can see that's not possible.
          Try double sided tape.
          Ron
          C-Note Iron Driver Build
          The Lydias
          The Cherry π's
          The Champs - Iron Driver 2015 Entry
          My Projects Page
          The good thing about science is that it's true whether or not you believe in it. - Neil deGrasse Tyson
          http://www.youtube.com/watch?v=cjuGCJJUGsg
            Maybe I'm not understanding the problem, but flip your jig around and cut the other direction?
              It's a zero clearance jig where you line the edge of the board up and just cut. No measuring for the blade etc. I could turn it around and set it back the width of the blade but was just trying to minimize mistakes.
                My guide is similar. I usually screw it to the work piece, unless the work piece is too small. In that case I screw the work piece to it, from underneath. You just need to use screws that won't go through all the way.
                www.billfitzmaurice.com
                  Yea I figured easy enough to just screw it to the work piece and fill the hole if I go all the way through. In the end no big deal but I was just scratching my head for a minute there hahaha
                    I have a similar jig and clamping is always a pita because of the motor clearance. If I clamp with my smallest F-clamps and place them strategically with the screw out of the way on the bottom, I can *just* barely get my motor to hop over the exposed clamp jaw with a little 1/8" bump. Short screws sounds like a reasonable approach. I also like the double-sided tape idea. I bought one roll a long time ago that worked great for a lot of projects. Haven't been able to find that kind again and everything else I've bough since then hasn't worked as well.
                    Good luck
                      Small C-clamps will give you plenty of clearance for the saw motor.
                      Bob
                        I cut the other way with the motor opposite the guide. I just use a long level and calculate the setback from the side of the saw to the blade.
                          Same here, just let a sheet rock screw "peek" past the surface. It works for me.
                          Kenny
                          http://www.diy-ny.com/
                            I use 4" spring clamps to hold down my guide. I occasionally run into small clearance issues like lowpolyjoe but only a small "hop" that doesn't show itself in the cut.
                              Working great clamping, screw, unclamp. Screw not even poking through the other side. Cuts are coming out amazing.
