I was wondering if anybody has used this amp http://www.amazon.com/gp/aw/d/B00MPD...eeL&ref=plSrch I was thinking about using it in a 2.1 boom box. I like the idea of using Tyger 23's Mariposas http://techtalk.parts-express.com/sh...A-HIBM65C20-8) and DanP's NRNP sub http://techtalk.parts-express.com/sh...A-HIBM65C20-8) I think the combination of the two designs would be quite compact and should work well together with the amp. What do you guys think?
Anybody used this 2.1 amp module?
Re: Anybody used this 2.1 amp module?
Originally posted by Jeff F. View PostI was wondering if anybody has used this amp http://www.amazon.com/gp/aw/d/B00MPD...eeL&ref=plSrch I was thinking about using it in a 2.1 boom box."A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Living Room Make Over
Originally posted by Jeff F. View PostI was wondering if anybody has used this amp http://www.amazon.com/gp/aw/d/B00MPD...eeL&ref=plSrch I was thinking about using it in a 2.1 boom box. I like the idea of using Tyger 23's Mariposas http://techtalk.parts-express.com/sh...A-HIBM65C20-8) and DanP's NRNP sub http://techtalk.parts-express.com/sh...A-HIBM65C20-8) I think the combination of the two designs would be quite compact and should work well together with the amp. What do you guys think?
http://www.ebay.com/itm/YJ-TPA3116-2...IAAOSw0vBUbAh8
The Good: Performs as advertised. Dead quiet when inserting/removing the 3.5mm signal cable, cycling the power on/off switch, and inserting/removing the DC power plug (w/ live voltage). Has performed reliably on several tests at high (e.g., max) volume for several hours at a time on the ".1" channel driving a 4ohm Peerless 830946 6.5" woofer (stays cool enough to keep your finger on the heatsink - barely). I have not tried it while also simultaneously driving the LR channels into 4 ohms (that test is coming soon). I have powered it with 26v (two freshly charged AGM-SLAs in series) with no averse effects. The pots are smooth so far.
The Bad: I don't have a discerning ear (bad hearing) nor quality speakers to determine if the module's use of electrolytic caps in the signal path effects the sound quality. The PS cap interferes with adding a screw terminal on one of the LR output channels (my solution: removed it and reinserted the cap on the under side of the board). There aren't any mounting holes, needs custom mounting arrangement. Gain is fixed at 26db. My PC line out drives to full volume, my phone needed the Sure $8 preamp (@PE) to achieve full volume.
Specs: The amp has a 1st order inverting band pass on the sub channel with a low end Fc of 34hz removing some of the low end bass (useful for controlling Xmax in my design, can be changed with a larger cap of same dimensions). The sub's LP is a 2nd order Butterworth filter fixed at 107hz. For my design I replaced the 2 caps in the LP filter to achieve an 2nd order LR at 1073hz. The ".1" channel is TPA3116 in PBTL mode rated for 2 ohms. The L-R are the individual channels of the 3116 rated at 4 ohm min impedance. My calculations indicate 55 watts at <1% THD into 4 ohms on all three channels using a 25V PS.
I reverse engineered most of the circuit. See the schematic attached (you can save the .png file to your PC for better viewing).
Originally posted by Gordy View PostI really wish it had a 3.5mm jack for an input. The JST connector is just harder to work with and crimp the connectors for.
Just found this one too http://m.ebay.com/itm/TPA3116-2-1-Ch....c100408.m2460 looks pretty good
Don't know about the amp, but the speakers are quite compact. I built separates and powered with Tyger 23's 2.1 amp. Be advised the NRNP sub is biased towards small size and simplicity. I have the sub placed in what you could call 1 pi space, in the corner of the bedroom with the nightstand adjacent. In this case, bass is quite good. Wolf's Biumph/Triumph(?) using the same driver but a little larger, might be a step up in performance.
I am quite happy with the system.
I set up the Yuan Jing 2.1 amp on my test box. I am using a Sure 4.0 BT module for input and a 12v battery pack for power. Initial impressions are that it has a lot more output than the PE 2.1 amp. This is probably driven in some part by the amplified output of the Sure BT module. The big downer is the woofer is crossed way to high. Sounds like it could be around 350z or a little higher. It just sounds muddy. I will put it through some more listening but to be honest, for my application, the PE 2.1 amp sounds better.
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Gordy, have you tried splitting the output from the Sure BT module to run two amp boards. I am thinking, run a 2 channel amp for L & R and a mono amp for the sub (possibly with a passive lpf). Mind you the xo would probably cost more than the amp.
Thanks for the test info Gordy! I wonder if placing one of these http://www.parts-express.com/parts-e...sover--266-444 in between the amp and sub would clean things up and get rid of the muddiness.
Originally posted by djg View PostI am quite happy with the system.
Originally posted by 01-0077 View PostGordy, have you tried splitting the output from the Sure BT module to run two amp boards. I am thinking, run a 2 channel amp for L & R and a mono amp for the sub (possibly with a passive lpf). Mind you the xo would probably cost more than the amp.
Originally posted by Jeff F. View PostThanks for the test info Gordy! I wonder if placing one of these http://www.parts-express.com/parts-e...sover--266-444 in between the amp and sub would clean things up and get rid of the muddiness."A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Gordy,
Thanks for doing this testing, can't wait to hear the results. I have been considering a 2.1 boombox for a while but the 2.1 amp board reviews have always put me off, especially in regard to low pass filters. Have you seen the NE5532 Subwoofer pre's on ebay? I was thinking about trying one out.
John.
Originally posted by Gordy View PostI also ordered the parts to see if I could make my own FMods. I made one for 150hz this evening out of mylar caps and 2% tolerance resistors and it kind of worked. It sounded a bit higher than 150hz but is robbed about 50%+ of signal. This idea may be a bust. Yes. this might be a good option. I will order one tomorrow and test it out. Costly option but it might just be simplest and the best.
Are you guys adverse to modifying the board itself. I had great success modifying my TPA3116's LP filter on the sub channel (see post #3). I could almost reverse engineer the TPA3123's LP filter from the picture on Amazon (but not quite w/o the physical module). And then this board is all surface mount requiring excellent soldering skills. My board had two thru-hole caps that I replaced.
Thanks for doing this testing, can't wait to hear the results. I have been considering a 2.1 boombox for a while but the 2.1 amp board reviews have always put me off, especially in regard to low pass filters. Have you seen the NE5532 Subwoofer pre's on ebay? I was thinking about trying one out.a
John.
Yes, I have one. Is has a frequency and level control. The level control works very well but the frequency not so much. It may be the driver and amp but it was a prelim test.
Originally posted by Millstonemike View PostThe attached are a mini tutorials on PLLXOs (sorry if this is redundant).
These are the the instructions that I used. I built a 2nd order low pass filter and it did work but it sucked 1/2 the signal. But I also was not using a 4ohm woofer on a dedicated 4ohm amp. that could have been a contributing factor.
I am not adverse modifying the board as a one off but I am as a production piece. For the time a trouble of modifying the amp it is just as easy to add a passive crossover."A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
