I have a pair of the 4 ohm Aura NS6 drivers and a set of Seas 27TDFC tweeters that I would like to use on this build, would like to keep it simple and not spend much if possible.
Box will be ~20L tuned at 45hz and a stepped 15mm woofer baffle .
Fc around 2.5khz 12dB/oct but will have to run measurements to see what's best.
Undecided on port location, front or rear.
This will most likely be used nearfield in a work desk or stands near the wall and not played loud, will be amped by a Lepai LP-2020A+. Trying to use as much parts as I already have.
Front baffle dimensions.
24cm wide
40cm tall
I'll run FR and phase measurements once I build the box, but I can't do impedance measurements at the moment.
I never built passive crossovers before, always gone the active route so I have no experience designing passives.
I have a spare DCX 2496 that I can use to simulate and try some crossover settings and FR shaping before building a final passive crossover, but like I said I would just like to keep it simple as this will be used in my small office/workshop and not have that much use.
I also have a set of Vifa BC25SC06-04 tweeters and B&C DE10 drivers but no waveguide for it, but would prefer to use the Seas tweeters.
Any help would be very much appreciated.
My main system uses B&C 8PS21 woofers and JBL 2408H drivers on the JBL 6x6 waveguide, MiniDSP bi-amped. Dual Aura NS8 for subs nearfield.
24cm wide
40cm tall
