Opinions on driver arrangement of four ND90-8s plus tweeter please.
  • #46
    Re: Opinions on driver arrangement of four ND90-8s plus tweeter please.
    sure
    • #47
      Thanks Chris,
      I'll get onto that Saturday. I'm thinking of testing all eight and averaging them. I'm mostly just curious if there is any major differences between them.
      • #48
        Hey Guys,
        I have some DATS v2 questions.
        When I measure the Vas using the test box method with the driver pointing inward, shouldn't I reverse the polarity on the test leads?
        Also, I keep getting the message saying the Fs was increased by less than 50%. I'm already using a .0343 cu ft box which seems petty small to me. Can anyone give me some pointers regarding this?
        Thanks,
        Matthew
        • #49
          I've always used the "added mass" method for Vas. A U.S. "nickel" is so very close to exactly 5.0 grams that any error is negligible. 15g would probably be a good starting point for an ND90. Test lead polarity won't matter.
          For added mass, you add enough to try to lower the resonance by at least 50% (I THINK? - might only be 25%?, DATS will tell you). For test box, you try to raise resonance by 50%. You'd just have to keep trying smaller volumes 'til you get there. I've heard of guys using small glass/ceramic jars/containers (w/gaskets) for small drivers.
          • #50
            What is the best way to attach the nickel to the cone?
            • #51
              I just lay them on there, driver face up, BUT . . . you can't block the vent on the back of the magnet, you've got to put some pressure down on the driver so it doesn't "jump" during the pulse/sweep, and if the nickels "jump" - you'll see it in a "jittery" impedance plot. Sometimes rearranging them (or adding 1 more) can smooth that plot out.
              I'd like to see your DATS results: your average, highest/lowest for each parm. Did you say you've got 8 ND90-8s? That's a good sample size.
              • #52
                So,
                Here's the DATS results for eight ND90-8s
                • #53
                  So . . . IIWM, I'd group BEFG in one box, and ACDH in the other (ave. those groups of 4 (each) and see if you don't end up
                  w/averages for Qts, Fs, and Vas close to you overall averages).
                  To ME, it looks like you'll probably end up reaching down into the mid 50s in about a 1/2 cu.ft. vented box.
                  Funny thing is (just for the BOX MODEL) you should be able to wire those "quad" groups up (on your board) in series/parallel
                  (8 ohms) and run T/S parms on the group and get Qts near 0.65 or so, and an Fs around 80 - which will verify your F3.
                  Don't have a good way to measure the Vas of a "quad", but SHOULD end up just a bit under 14 liters.
